Any trick to removing floppy drive without breaking anything
Postby Corey986 » Wed Mar 04, 2015 6:47 am
If I'm reading things correctly to get access to the CPU to install my V20 chip I need to remove the floppy which has those silly snap in Tabs on the bottom. Any trick to "popping" them and not breaking anything?
Thanks,
Corey
Corey986
Re: Any trick to removing floppy drive without breaking anyt
Postby jmetal88 » Wed Mar 04, 2015 7:12 am
I don't know of any trick, unfortunately. I just grab the back of the drive and yank it upwards while trying to keep the rest of the computer in place. In the two that I've had so far, I've never broken anything that way, although I have broken one set of tabs on the cover that goes over the outer sidecar while yanking it out of place (I actually fixed that by gluing an eraser from a BIC mechanical pencil to the spot where the tabs broke, though).
Postby Trixter » Wed Mar 04, 2015 11:31 am
I turn the system unit upside down, and use a thin object (like the eraser end of a pencil) to push, slowly and with even pressure, the tabs through. If you're worried about drive damage as the last tab pops out and it falls from the case, put a cloth under it as a cushion when you turn it over.
Users browsing this forum: MikeModified and 2 guests
