JrConfig Configuration and Other Questions
Re: JrConfig Configuration and Other Questions
Postby jmetal88 » Fri Nov 09, 2012 12:25 pm
I'm guessing the original version had an install program that only copied the correct files for the machine chosen, and that whoever uploaded the online copy just used their installed copy, instead of copying the installation disk.
Postby Tempest » Fri Nov 09, 2012 12:44 pm
I'll keep looking then. It must be out there.
Postby Tempest » Sat Nov 10, 2012 8:05 am
As long as I have your attention, I have another question. When I turn on PCjr and it goes through its normal start up sequence and the text is very bright (which I like). However when it comes to the part where jrConfig loads and it does a soft reset and loads again, the text is suddenly half as bright. What causes this and is there a way to keep the text brighter?
Postby jmetal88 » Sat Nov 10, 2012 9:27 am
That's something DOS does, setting the text to grey instead of white. Unless you can find some external utility to change the color back to white in AUTOEXEC, I can't think of any way to change it back to white without using ANSI.SYS and manually entering escape codes.
Previous
