The Electronic Library
Postby Tempest » Mon Apr 13, 2015 6:51 pm
Has anyone seen a program called The Electronic Library? I picked up this disk along with the Store Name Customizer disk and some instructions this weekend. I guess it's supposed to be a running demo that shows off some PCjr software, but sadly I couldn't get it to work. It loaded the first screen that said PLEASE WAIT and then the disk drive ran forever never reading the disk. This could mean the disk is bad, or more than likely a product of either my flaky disk drive or incompatibility with the DOS version (says it wanted 2.10 but all I had hand was 3.30). The program also needs the BASIC cartridge plugged in, so it possibly could have had problems with the JRIDE somehow. I'll have to try unhooking it later and see if that helps.
Re: The Electronic Library
Postby Trixter » Thu Apr 30, 2015 1:07 pm
Can you dump both disks to image files on another computer and upload them somewhere? My PCjr is out this month and set up on a table next to me, so I can give it a shot.
Postby Tempest » Thu Apr 30, 2015 5:56 pm
Are you going to be at VCF Midwest? I can bring them there for dumping if you want.
Postby Trixter » Thu Apr 30, 2015 8:36 pm
I certainly am, and we certainly can. :-) Don't forget!
Postby Tempest » Fri May 01, 2015 9:12 am
I'll bring them for sure. I'll go stick them in 'The Pile'
