Re: Paku Paku -- new DOS Game released -- VER 1.2!!!
Postby jmetal88 » Thu Feb 10, 2011 8:03 am
I can't wait to give it a shot! I won't have access to my PCjr until Friday evening though - I didn't think I'd have room for it here in my dorm, so I left it with my parents in Bartlesville.
Postby Vorticon » Thu Feb 10, 2011 11:04 pm
Second version is absolutely faster, almost too fast for arrow keys play! Is it possible to implement joystick support? Once again, great work :)
Postby deathshadow60 » Fri Feb 11, 2011 12:17 am
Vorticon wrote:Second version is absolutely faster, almost too fast for arrow keys play! Is it possible to implement joystick support? Once again, great work :)
Joystick support is on my to-do list for 1.3, I'm also playing with the idea of supporting the PPJOY type parallel adapters directly. That will top off some tweaks to the audio subsytem, removal of legacy/unused code, and thanks to the vintage PC forums, proper support and detection of MCGA video on PS/2 model 25 and 30's.
I'm still trying to decide how much dead zone to implement, and how I'm going to interpret diagonal inputs.
deathshadow60
Postby Vorticon » Fri Feb 11, 2011 6:29 am
In my experience, when only orthogonal directionality is needed, diagonal input occurs inadvertently when players attempt to move up or down, which is how I think you should implement it.
Postby jmetal88 » Sun Feb 13, 2011 12:58 am
I wanted to try this today, but it seems both 5.25" floppy drives I've been using in my 'data movement' machine have failed. :(
Once I figure out some other way to move data to my PCjr, I'll let you know what I think. :)
Postby Vorticon » Sun Feb 13, 2011 7:28 am
jmetal88 wrote:I wanted to try this today, but it seems both 5.25" floppy drives I've been using in my 'data movement' machine have failed. :(
You should give Mike's FTP server a try :) Once configured, it's completely painless to transfer data to the Jr from any other computer on your home network. I use the free version of WS-FTP on the Windows side which has a nice GUI and easily allows you to manipulate files and folders on the Jr side.
Postby jmetal88 » Sun Feb 13, 2011 8:41 am
That's not gonna work for an immediate solution, as I don't have a parallel port ethernet adapter yet. :lol:
Luckily, whatever blew up the two 5.25" floppies on my 'data movement' machine did not affect the 3.5" floppy on that machine, so I can still use that machine to copy stuff on to my ZIP drive, which can then be used on my PCjr.
Postby jmetal88 » Sun Feb 13, 2011 8:58 am
Alright! Just played this sucker on my Jr, and man, is it fast! You did a great job, working the game into such a low-res space. It'd be great to see a higher-res PCjr/Tandy only version of the game, too, though. :)
EDIT: I have a question though. Did changing the sprite engine for version 1.2 change the look of the game? It's just that what I have on my PCjr doesn't quite match the screenshot you have on your site. I'm seeing vertical brown stripes in most of the yellow stuff, and when the on-screen items 'flash' it looks like an extra pixel gets added to the left of things.
I am tempted to try the game off floppy from DOS 3.3, though, to see if maybe my Jrconfig settings are causing any of these issues.
EDIT 2: Nah, it does the same thing from DOS 3.3. Still fun, though!
Postby Brutman » Sun Feb 13, 2011 12:20 pm
The sound is good, the performance is fine, and the gameplay is good as well. But there is definitely something weird going on with the PCjr video. Here is a screen shot of the effect that JMetal88 is trying to describe:
It's not serious .. a little quality time in the code is probably all it needs. (It looks like every 4 or 8 bits highlighting is turned on.)
Postby Brutman » Sun Feb 13, 2011 12:24 pm
Not to hijack the thread ... just some quick notes:
- I personally wouldn't run FTPSRV on a Jr unless it was for kicks. The FTP client is smaller so it loads quicker, it uses less memory, and the data transfer rates should be faster. Run a real FTP server on a Windows or Linux machine, and use the Jr as a client.
- I know somebody who has the Compex adapter now. We're waiting to hear test results. If they work, I'll pick up one for testing. While I like the Xircom, there are more reasonably priced Compex adapters on eBay at the moment than Xircoms. And if the performance and function are close, then it is a win.
