I started with adding it to my system as it was configured (2 parallel port sidecards, 1 512kb sidecar, plus a PC Enterprises 5 1/4" HD drive powered up and connected to the parallel port). I noticed that I had issues getting it to recognize my CF to IDE adapter card. Long story short, I discovered that if the system had ANY cartridge in any slot, it would not recognize any IDE devices connected to the jrIDE. I even took it down to just 1 parallel port card and the jrIDE, same issue. I checked the BIOS and it has the latest BIOS on the jrIDE that from what I read is supposed to address an issue with the cartridges.
So recently I went with the jrATX power adapter card and a picoATX power supply and everything was happy. So I experimented and plugged my BASIC cartridge back in and lo and behold, the jrIDE worked just fine. I then proceeded to plug in a game cartridge and...same thing, it's happy and I can select my boot device and it works perfectly.
Is this a symptom that the system was marginal on power? Before the ATX P/S swap it had the larger PCjr power supply card inside which to my understanding was around 70 watts, at least when new? So it didn't have the 30ish watt power supply, which would never have powered all those sidecars anway.
Also, does anyone know of a IDE to CF card that takes power off pin 20? All the ones I see have that pin removed
