PC Enterprises Motherboard Modification Identification
vonhelmst
Post by vonhelmst »
Hoping someone can assist in identifying PCE modifications shown in the pictures below.
Does the TI chip have something to do with video?
The POST screen shows a slightly different sharper font when counting memory.
Not sure if the F3D2 chip is a modification but it is socketed on this board and my other jr mobos are not.
Thanks,
Sonny
Re: PC Enterprises Motherboard Modification Identification
The "thin font" upgrade was an advertised PC Enterprises modification; it replaced the stock font with the thin variant (which is present on all CGA cards, you just need to bridge two points; more info here: http://nerdlypleasures.blogspot.com/201 ... fonts.html).
In my opinion, there is little reason to do this on a PCjr unless you're hooking it up to an extremely high quality, fine dot pitch monitor (better than the 5153). It also has some ramifications running software that tried to paint graphics in tweaked/hacked text modes, as the "pixels" no longer line up. However, a PCjr board with this modification is very uncommon, so to preserve the value of the board, I would not undo it.
As for the rest of the modifications, your question is answered on the last page of https://www.brutman.com/PCjr/docs/PC_En ... ations.pdf which states that modification "97514" was "expands memory on PCjrs from 640K to 736K". That's a good mod, since it "recovers" the first 128K of the system lost to video memory, giving you a workable 640K again.
vonhelmst
Post by vonhelmst »
Thank you.
Appreciate your response.
Sonny
