Jr Cartridge blank for eprom
Re: Jr Cartridge blank for eprom
I thought Cartridge BASIC added a file to DOS's 'vocabulary' - a sort of non-traditional ROM BIOS extension that supplied a file name and entry point rather than being directly executed.
-Alan
-Alan
It looks like DOS executes the BASIC.COM program which then tries to wrapper the ROM BASIC. I think that happens on a PC or an XT too. On a Jr though, attempting to run the built in Cassette BASIC in this way results in the "Cartridge Required" message. I'm not sure if there was a technical reason for that - probably more to do with getting people to buy the cartridge. The "Cartridge Required" message is coming from the system ROM.
And yes, if you look at the beginning of the BASIC cartridge you will see a ROM signature, initialization code, and the 'BASIC' command that DOS knows to look for. Cartridges can also include BASIC code with a slightly different signature.
In the beginning of BASIC cartridge I think they have both names - BASIC and BASICA, but anyway - it's not working with JR-IDE and DOS 3.20 - BASIC immediately exited back to DOS and BASICA simply hung (with BASIC cartridge inserted)
Actually it is not a big problem for me because now I have TurboC 2.01 that is running pretty well
P.S. I didn't try TurboC++ yet, because its box states that 286 is required...
I found "RNC Pro Pack" and Exomizer. It looks like Exomizer can't handle big files, so I tried RNC only (both methods) plus added a few retro DOS archivers results:Trixter wrote:As for "optimal way", that's called "optimal parsing", which is a way to guarantee the most efficient matches (offset+length) of the source material, at the cost of speed. Storer and Szymanski described it in their 1984 paper that described LZSS, if you want to look it up out of curiosity; their solution was to parse the data BACKWARDS which initially seems wacko but makes sense if you think about it. LZ4, ZX7, MegaLZ, and exomizer all have an optimal parsing option. Don't know if RNC Pro Pack does, but it still performs competitively.
147,456 JRCARTS7.IMG - original
130,281 JRCARTS8.IMG - my 00-00-00 compression
103,307 JRCARTS7.PP2 - RNC Pro Pack (method 2)
101,009 JRCARTS7.ZX7
100,180 JRCARTS7.IMG.hrm - Russian Hrum
99,974 JRCARTS7.IMG.mlz - Russian MegaLZ
98,006 JRCARTS7.LZH - created by LHA v2.13
80,016 JRCARTS7.IMG.bz2
79,098 JRCARTS7.LZ4
72,959 JRCARTS7.PP1 - RNC Pro Pack (method 1)
71,950 JRCARTS7.zip - modern ZIP from Debian
71,925 JRCARTS7.ARJ - created by ARJ v2.41a
71,865 JRCARTS7.AIN - another Russian archiver from 90s
71,855 JRCARTS7.ZIP - old PKZIP v2.06
71,808 JRCARTS7.IMG.gz
70,041 JRCARTS7.HA - HA 0.98 (Harri Hirvola)
67,437 JRCARTS7.IMG.hst - Russian Hrust
66,970 JRCARTS7.RAR - old RAR v1
65,765 JRCARTS7.RAR - modern RAR v5
62,543 JRCARTS7.7z - modern 7-zip
62,508 JRCARTS7.IMG.xz - modern LZMA2
I've been working on a nice little LZW compressor/decompressor that would be interesting to try out on your image. It's never going to get as good as ZIP (because I don't want to invest the time), but it also works much faster too.
(I'm going to use it mostly for text compression. It's basically equivalent to the old Unix compress program.)
I sent you original binary by e-mailBrutman wrote:I've been working on a nice little LZW compressor/decompressor that would be interesting to try out on your image. It's never going to get as good as ZIP (because I don't want to invest the time), but it also works much faster too.
I'm also working on LZ-like compression utility
Most of the work was done in October 2013 and since that time I can't find a night or two to finish it...
I finished version 0 of my LZ77-like compression (byte-oriented) that I designed in October 2013:
https://github.com/shaos/shaff
and it put me closer to RNC Pro Pack 2 and ZX7 in terms of compression ratio:
it means now I've got 18KB for menu program!
112,715 JRCARTS7.IMGFF - my byte-oriented LZ77-like compression (SHAFF0) <<<<<
SHAFF0 format is very simple:
SHAFF0 decoder in C:
XX - any byte other than #FF is a single data byte
#FF #00 - single byte #FF
#FF 0xxxxxxx LENGTH (distance -1...-127)
#FF 10xxxxxx LENGTH (distance -128...-190 and -191 means last distance longer or equal to -191)
#FF 11xxxxxx xxxxxxxx LENGTH (directly encoded distance from -191 to -16383)
special case without LENGTH:
#FF #C0 #00 - end of block (instead of distance -16384)
i = 0;
while(i<=cursize)
character = fgetc(f);
if(character==0xFF)
if(character==0) /* Literal 0xFF */
buf[i++] = 0xFF;
else /* Reference */
/* Decode offset */
if((character&0xC0)==0xC0)
offset = (((short)character)<<8)|((short)fgetc(f));
lastoffset = offset;
if(offset==-16384)
/* Marker of the block end */
if(i!=cursize)
printf("ERROR: Something wrong with size (%i)...\n",i);
break;
else if(character==191)
offset = lastoffset;
else
offset = -character;
/* Decode length */
if((character&0xC0)==0)
length = (character<<8)|fgetc(f);
else if((character&0xC0)==64)
length = character + 68; /* 132-64 */
else
length = character - 124; /* 4-128 */
j = i + offset;
if(j < 0)
printf("ERROR: Something wrong with offset (%i)...\n",offset);
else
do
if(j>=cursize)
printf("ERROR: Something wrong with size (%i)....\n",j);
else buf[i++] = buf[j++];
} while(--length);
else /* Literal */
buf[i++] = character;
Cute :-) Your decomp inner loop would look something like this:
61 cycles if code encountered, 49 if literal, 8 bytes.
But if you change your codes to be at the end, you can do this:
This is both smaller and faster on 8086. It shifts the bits into carry and jumps based on carry bit, and when you're finished you don't need to adjust the value as it is already in the correct format.
EDIT: I just thought of another optimization: Don't use FF for the code; instead, use the value that shows up the least. Scan the entire file before compressing to determine which value shows up the least, then use that as the code. Otherwise, data that has a lot of FFs in it (like most 8-bit programming!) won't compress very well...
12 0866:0100 AC LODSB
04 0866:0101 3CFF CMP AL,FF
16/04 0866:0103 742B JZ 0130
11 0866:0105 AA STOSB
18 0866:0106 E2F8 LOOP 0100
If you care about decomp speed, you might want to put codes at the end instead of the beginning. For example, 1xxxxxxx means this is necessary:LENGTH is 1 or 2 bytes:
1xxxxxxx - for 4...131
01xxxxxx - for 132..195
00xxxxxx xxxxxxxx - for up to 16383
cmp al,10000000b
je handle_1
handle_1:
and al,01111111b
add al,4
shr al,1
jc handle_1
handle_1:
add al,4
I'm not going to win this competition anytime soon ... my general LZW algorithm took 147456 bytes of input and produced 132797 bytes of output. Which is reasonable considering the binaries look like random data, but not great when simple heuristics that take advantage of the structure of binaries can beat it.
My output codes are fixed at 12 bits long, so I have to overcome a 50% penalty right from the start. If I had the variable bit rate part done I would expect most of the output codes to be 9 bits for this file size, thus taking another 25% off of my output size.
