Keyboard Squeak
Keyboard Squeak
Post by Tempest »
The spacebar on my pcjr keyboard (non-chiclet model) is squeaking rather badly and it's becoming an annoyance. What's the best way to fix this? Can I pry the spacebar up with a screwdriver and spray a lubricant on the plungers or are they attached differently on the pcjr keyboard? I don't want to try and force the keys if they can't be removed.
Sharkey1331
Re: Keyboard Squeak
Post by Sharkey1331 »
I'm interested in this too, as my Enter button squeaks, and also I'd like to disassemble the keyboard to give it a good clean..
IBM PC Jr. NEWB! Parallel sidecar, jrIDE, NEC V20, JRCONFIG, Xircom PE3 + IRCjr!
Re: Keyboard Squeak
Post by GHiero »
If I remember right, there is no metal retaining bar giving the spacebar the extra spring to return to its natural position. Instead, there are some plastic bits that do the same thing. Silicone lubricant should help you out here.
Re: Keyboard Squeak
Post by Tempest »
GHiero wrote:If I remember right, there is no metal retaining bar giving the spacebar the extra spring to return to its natural position. Instead, there are some plastic bits that do the same thing. Silicone lubricant should help you out here.
But can you just pry the spacebar out with something like a screwdriver?
Re: Keyboard Squeak
Why risk something by prying when you can just undo four screws on the back and get to everything you need?
MikeModified
Re: Keyboard Squeak
Post by MikeModified »
Brutman wrote:Why risk something by prying when you can just undo six screws on the back and get to everything you need?
Fixed it for ya, Mike ;) , including one under the serial number sticker, lower center.
Re: Keyboard Squeak
Post by Tempest »
No more squeak! Actually now the keyboard is almost too quiet. :)
