I am interested in making an adapter that allows PC joysticks to work in a PCjr. Fortunately the sticks work exactly the same, so you only need to match DA-15 pins to the 2x4 arrangement of the PCjr. pins. Here is how to do it :
PC - JR
1 - A4 +5v
2 - B2 X-axis
3 - B4 Button 1
5 - A2 Ground
6 - A3 Y-axis
7 - B3 Button 2
A1 is keyplug
Female DA-15 connectors are easy to come by, but is there any source for the plug the PCjr. devices use or a functional equivalent? Hopefully keyed! I would note that it could be
very bad to insert this plug into your PCjr upside down because you have connected the +5v pin at A4 to the shield ground pin at B1.
