Happy Holidays
Say hello here!
Shaos
Re: Happy Holidays
Post by Shaos »
KenG wrote:Once you get that going, you need to install a battery and the clock software.
This was my 2nd question - which exact software I should use to setup the clock and feed date/time to DOS on boot?
Shaos
Re: Happy Holidays
Post by Shaos »
Shaos wrote:
Hargle wrote:Assuming it is supported in DOS 3.2, try "fdisk /mbr" and reboot. Lots and lots of boot issues on the XT-IDE project have been resolved with that simple step.
yea, I didn't do this one - will check this evening, thanks!
Another question - anybody tried 2 CFs on JR-IDE? One as Master and another one as Slave? I found dual adapters 2CF-to-IDE on Ebay and just curious if it's supported here...
Re: Happy Holidays
I've never used the clock on the jrIDE ... the software is floating around with a link somewhere in the forums; I'll get that fixed so that it is in a more easily discovered location.
As for 2 CF cards, I wouldn't try that just yet. I'm looking to get some time to scrub the BIOS code and make sure nothing terrible happens. It's based on Hargle's original BIOS for the XT-IDE so there are some weak spots, like error handling.
Re: Happy Holidays
Post by alanh »
The clock utility is available here:
https://www.retrotronics.org/jride/
Re: Happy Holidays
Post by KenG »
Getting the BIOS fixed so that two devices work would be great. DOM as master and CF slave for file transfers and backing up the DOM. I use my Parallel port CF now, but it is slow and the driver software is rather large.
Shaos
Re: Happy Holidays
Post by Shaos »
alanh wrote:The clock utility is available here:
Oh, in "Related Files" on the left of the page - I didn't notice it right away :)
P.S. I found instructions how to use it: http://nerdlypleasures.blogspot.com/201 ... rades.html
The RTC is a Dallas 12887 module, and is socketed for replacement. The date and time is set by a program called rtc, loaded in the autoexec.bat file on startup. IRQ 1, 2 or 7 can be selected for its operation. I suggest IRQ2 because the parallel port uses IRQ7 and the keyboard on a regular PC uses IRQ1, which could possibly confuse some programs that are not PCjr-aware. The Speech Attachment also uses IRQ1.
In order to set the date and time, you will need a small program called rtc.com, available here:
http://www.retrotronics.org/svn/jride/t ... ebuilt/jr/
To set the date and time for the RTC, first, set the correct date and time in DOS using the DATE and TIME commands. Next, run the rtc.com program with the /r switch. This will send the date and time you told DOS to the RTC. Finally, add the rtc.com program to your autoexec.bat file with the /d switch. Upon every bootup, this will fetch the correct date and time from the RTC and automatically set it in DOS.
Re: Happy Holidays
Post by Hargle »
Two drives on the jrIDE works just fine. I did this not too long ago:
http://www.brutman.com/forums/viewtopic ... =440#p1934
The BIOS has full support for two drives. The bug Mike is referring to is that it isn't correctly catching access to a 2nd drive when it doesn't exist, so in fact you're going to be LESS buggy if you run both drives at the same time. :)
Shaos
Re: Happy Holidays
Post by Shaos »
Thanks! I thought something like that when I saw how jrIDE BIOS was hanging for a while on 2nd drive detection ;)
Shaos
Re: Happy Holidays
Post by Shaos »
Finally :)
Boot takes 72 seconds from Power-Off and 48 seconds by Alt-Ctrl-Del :roll:
P.S. Disk D was created by JRCONFIG.SYS /V32 /L /R
(228.92 KiB) Not downloaded yet
(208.5 KiB) Not downloaded yet
Shaos
Re: Happy Holidays
Post by Shaos »
Alley Cat :)
(253.89 KiB) Not downloaded yet
