Ethernet for PCjr {WizNet}
Re: Jr Cartridge Ethernet {IDEA}
Does somebody have signal description/diagrams for modem slot?...
Nevermind, I found it in PCjr Technical Reference book:
So it's only 4 address lines? I guess reading from internal WizNet 32K memory will be much faster in case of cartridge than modem slot...
P.S. But actually in indirect mode of W5100 chip, when only 2 address lines are used instead of 15, and with help of automatic increment of the address (to avoid setting it for every byte), it may work with similar speed!
A1 - D7 B1 - 5V
A2 - D6 B2 - /MODEM CS
A3 - D5 B3 - A9
A4 - GND B4 - /TXRES
A5 - D4 B5 - GND
A6 - D3 B6 - A2
A7 - D2 B7 - A1
A8 - GND B8 - A0
A9 - D1 B9 - GND
A10 - D0 B10 - /IOR
A11 - MODEM INT B11 - /IOW
A12 - GND B12 - GND
A13 - BAUD CLK B13 - /CARD INST
A14 - 5V B14 - TXRES
A15 - 12V B15 - 5V
- Attachments
- (125.57 KiB) Not downloaded yet
You are right - it fits perfectlyTrixter wrote:Additionally, no case modifications would be necessary, since the window is wide enough for an RJ11 and will probably take an RJ45 just fine.Brutman wrote: For Ethernet I'd love to see something in the modem slot. It has an interrupt line. It has I/O ports. Putting wired Ethernet in there should be easy.
The only problem - WizNet module will be 90 degree to the vertical board (and upside down) so I should invent some interconnection between them:
In case of indirect mode of W5100 this module (WIZ812MJ for $30) could be almost directly connected to the modem slot, so my interface board will have 3.3V regulator (chip is 3.3V, but all inputs are 5V tolerant), a transistor to convert 3.3V signal back to 5V for interrupt signal, a few resistors and may be a serial EEPROM to store MAC-address (W5100 doesn't remember anything after reset) - so it has to be relatively cheap right away like $50 with WIZ812MJ module or $20 without and bare board will be even cheaper!
P.S. Actually it looks like /CS is shared with floppy controller and A9 should be used to differentiate them:
if A9=0 then it's floppy
if A9=1 then it's modem
so it will be some logic glue as well...
- Attachments
- (49.55 KiB) Not downloaded yet
- (54.19 KiB) Not downloaded yet
Yes, you are correct. ZM52 (ROM) decodes that chip select - asserting it for addresses 0F0h->0FFh (floppy) and 3F8h->3FFh (UART).
Ok, thank you for confirmation! Do you know if BIOS (or DOS) is doing something with these ports on initialization if modem card is inserted?alanh wrote:Yes, you are correct. ZM52 (ROM) decodes that chip select - asserting it for addresses 0F0h->0FFh (floppy) and 3F8h->3FFh (UART).
P.S. I found it - BIOS calls subroutine UART with modem base address if card is inserted, so I guess solution is not to ground /CARD INST to prevent this call, right?...
- Attachments
- (66.12 KiB) Not downloaded yet
That would make sense
Also I didn't find anything else on schematics for what this signal (/CARD INST) is used in hardware except for going to port C to be read by BIOS on startup, so my assumption is all other lines in modem slot will keep working even if /CARD INST is not grounded
Even if the number of ports is too limited, we can do something in the packet driver to enable multiplexing of addresses similar to the way older graphics cards (EGA?) have you select a register before writing to it. I wouldn't be too concerned about that; we'd just try to make sure the ports requiring the latching are less used than the performance path ports.
People have stuck other cards in the modem slot before; a SCSI controller in particular. I think that card select line is just really there for the benefit of the BIOS. If I stick a logic probe on any of the pins I'm sure I can make them wiggle without card select engaged.
Yes, for now I think WizNet module with W5100 chip onboard looks surprisingly well suitable for this modem slot
Why not wi-fi?Brutman wrote:
For Ethernet I'd love to see something in the modem slot. It has an interrupt line. It has I/O ports. Putting wired Ethernet in there should be easy. Wired Ethernet isn't as cool as the jrIDE based emulated hard drive/wifi/Linux co-processor that Alan isn't work on, but it also doesn't require a jrIDE and it's really simple in comparison.
