Broken Screw
PNKlett
Broken Screw
Post by PNKlett »
Hi, I overtightened one of my sidecar screws and it broke. Does anybody have experience removing the screw?
It's just below the top and I can't use a screwdriver to remove the screw that it's broken in.
Any help would be appreciated.
Thanks!
Paul
Re: Broken Screw
There are tools for this sort of thing: https://www.familyhandyman.com/tools/ex ... /view-all/
The PCjr sidecar screws are very thin, but hopefully this will get the job done. If not, you'll have to try to put a wedge between the sidecar and the case, and use a thin saw in whatever gap you can create and saw through it.
PNKlett
Re: Broken Screw
Post by PNKlett »
Thanks Trixter!
I forgot about those screw removers.
Paul
C20562236
Re: Broken Screw
Post by C20562236 »
Did you manage to remove the screw ??
PNKlett
Re: Broken Screw
Post by PNKlett »
Hi, Yes I did but with a 1/4 inch drill. The screw remover didn't work to good.
Paul
