PC DOS 5 Editor
PC DOS 5 Editor
I finally built my second jrIDE sidecar and have PC DOS 5.02 running great on it. I'm having trouble using the DOS edit.com program... the keyboard gets wacky and I can't type anything. I'm using a PCjr keyboard. Is this a known issue? Is the PCjr keyboard incompatible? Any good alternatives to using the DOS Editor?
Re: PC DOS 5 Editor
Distant memory says that edit.com doesn't work. Are you seeing double keystrokes for each key you hit?
I think there is a fixbas.sys device driver that fixes this, but it might be another device driver. I have to go looking to figure it out.
Any text editor that does not add weird control characters should work. (Word processors generally add control characters, so don't use them.)
Re: PC DOS 5 Editor
Yes exactly, double keystrokes at first then no response. I couldn't find fixbas.sys on the web ... do you have a copy?
Re: PC DOS 5 Editor
If I remember correctly, Edit requires BASICA and doesn't work correctly with the basic in the PCjr. I use other editors, but I don't remember which one I like best or their names. I haven't used my jr in a while.
EDIT: I believe it is this one http://texteditors.org/cgi-bin/wiki.pl?Xted
Re: PC DOS 5 Editor
KenG,
Edit definitely does not require BASIC in any form.
Jscrow: I'll get it posted. I'm away from home for the moment so it's going to be a few days. Fixbas.sys also makes it possible to run BASIC from the cartridge instead of using something like jrbasic that does the fix-up and relocation that is needed.
Re: PC DOS 5 Editor
OK, I remember it didn't work on my PCjr when I upgraded to DOS 5. I thought I got a message about BASIC, but it has been a while and my memory isn't what it used to be.Brutman wrote:KenG,
bagelswitch
Re: PC DOS 5 Editor
Was fixbas.sys ever posted anywhere (or is anyone willing to share it)? I'm having the same problem with edit.exe reported here (doubled keystrokes), and would like to use edit (rather than other, working editors) under DOS 5 for purely nostalgic reasons
Re: PC DOS 5 Editor
[quote="Brutman"]
[quote]
I could have sworn the MS-DOS 6+ EDIT.COM requires QBASIC.EXE in the PATH.
[quote]
Re: PC DOS 5 Editor
It absolutely does. EDIT.COM isn't even its own program, it just calls QBASIC.EXE in text editor mode.Trixter wrote:Brutman wrote: Edit definitely does not require BASIC in any form.
Re: PC DOS 5 Editor
My bad - the official DOS edit.com does indeed use QuickBasic. edit.com is only 413 bytes.
So now I'm wondering what other file called EDIT.COM I was confusing it with ...
(/me slinks back to my hole ...)
