Hello!
This is my first post on this forum. Glad to join the group!
I've been poking around the internet trying to resolve various issues with the PCjr I got from my older brother. It's a rather nice specimen, with the better keyboard, optical mouse, and modded memory sidecar bringing it up to 640k. I replaced a faulty 64k memory card, fixed the keyboard cable (optical doesn't work at all), and dealt with some broken switches on the bottoms of the controllers. The system is now working, and I can relive my childhood by playing Jumpman and Crossfire with the correct, PCjr-only, lego-block colors. The only issue remaining is with the disk drive. It will read, but won't write.
I did a little research and found out how the write protection is an optical sensor. I popped out the LED, and it doesn't appear to light up at all when the disk tries to write. I got a flashlight and pointed it at the sensor while the drive was trying to write, and after many tries I got it to save my niece's Lode Runner level, but this only worked once. Since then I've tried this trick a lot, but had no success.
The obvious solution would be to replace the LED, but now I'm not convinced the sensor is working either. Can I bypass the optical sensor entirely? As a cheap fix, if I just clip and solder the connection directly, does the drive always function as write-enabled?
I also made the uneducated choice of purchasing a 360k Teac 54b 5.25 floppy drive, which I naively thought would work as a replacement. Unfortunately, I haven't had any luck getting this drive to function, and am now realizing that perhaps not all 360k 5.25 floppy drives are interchangeable.
Any advice would be appreciated.
Thanks!
-Alaric
Floppy Drive won't Write
Re: Floppy Drive won't Write
I’m not sure about the sensor. It may not be visible. It may be infrared. As to the other drive. It should work if set up right. There should be jumpers or switches to set the drive number. I think it should be set to D1. You can check the old drive and set the new one the same.
Thanks for the reply.
The jumper was set to DS0. I changed it to DS1 and everything works! It was a bit of a squeeze to get the drive in place, but now it's working perfectly.
All the best,
-Alaric
All the best,
-Alaric
You've got this settled already, but I don't never recall seeing the write protect sensor "light up." I think it's not in the visible spectrum, and probably infra-red given the time period.
When something fails always look for the mostly likely cause first. In this case, human error.
I’m glad I was able to help you get it working. Enjoy,
