Machine boots and runs fine - for a while. After a period of time (approx 30 to 45 minutes - not exactly timed) a reboot will produce a scrambled screen as shown:
This is the IBM Logo. You can kinda guess what is going on.
This is what I have observed so far:
- Failure only occurs on reboot.
- Sometimes it recovers by itself on a mode change (for example, 40 to 80 columns).
- Sometimes it can be resolved by turning the monitor off and on again. But this is not always reliable.
- Reboots do not seem to help.
- Turning the machine and monitor off and waiting 5-10 minutes resolves the problem.
- Turning the monitor off (and leaving the PCjr running) for about 5 minutes has been tried 1 time and was successful.
- The machine continues to boot despite the display problems. You can guess what is happening behind the scenes if you are familiar with the boot process.
There is an ebay listing showing a monitor with the the same behavior here: https://www.ebay.com/itm/ibm-pc-jr-disp ... SwQzJb7c5A so I don't think I am unique in having this happen. (To clarify, the ebay link is not my monitor.)
I am hoping that I am not the first to see this problem, and that the fix is easy.
Has anyone seen this failure mode before or am I just lucky?
If it has been seen before, is the known cause the monitor or machine?
Is there a known fix?
