I've been looking for another Compact Printer for a while. I finally found one at a decent price and it arrived yesterday.
The first problem was loading the paper. I think the printer has a small problem with one of the pinch rollers not disengaging, which made it difficult to get the paper fed. It is on a roll so that was just irritating for 20 minutes.
Next was remembering how to print to it. Text is easy but I wanted to test the graphics mode. I have a test file that is a binary file already formatted for the printer (using the escape codes for graphics), but it kept cutting the print short for some reason. I thought it was overrunning the serial port so I played a bit with the MODE command, but it was simpler than that. When copying binary files on DOS to non-file destinations always use the /b switch to indicate a binary copy. Otherwise an embedded CTRL-Z in the data stream will end the data transfer.
Then my Xircom adapter packet drive would not load. I checked the power a few times and then realized that the @#$@# BIOS moved LPT1 because the printer was plugged in.
Anyway, for your amusement, the IBM Compact Printer in action:
https://www.youtube.com/watch?v=7y_WE40sMlk
For bonus points try to identify all of the stuff on the workbench. ;-0
PS: Has anybody bought paper for this recently? It is just thermal fax paper on a 1/2 inch spool. I've seen some six packs at Office Depot and on Amazon, but before I commit I want to see if anybody else has recent experience. (1 roll is a lifetime supply. To use 6 I'm going to have to make an "8 bit Photobooth".)
IBM Compact Printer video (Watch it Print!)
Re: IBM Compact Printer video (Watch it Print!)
I spy with my little eye:Brutman wrote:For bonus points try to identify all of the stuff on the workbench. ;-0
- Analog film canisters (wtf?)
- 6 PC miniature models (you have a problem)
- jr-PSU uninstalled (why do I bother?)
- Zip disks
- What looks to be a keytronic numeric keypad for the JR
- A late model Lexmark Model M
- What looks like a Logitech MouseMan but maybe the optical mouse for the JR
- Not enough work-space.
Good use of an "I Spy" reference ...
Oh, and not enough workspace. : - )
- Film canisters: for holding small parts.
- PC minatures (I have a problem. They were cheap though.)
- jr-PSU - My main system on the bench has an ATX power supply already for the external hard drive. The jr-PSU was tested in that system but is destined for another system I'm building for show purposes. (That system will have a jr-IDE, jr-PSU, Model M keyboard, Zip drive, Xircom adapter, etc. I'm debating on whether to use an expansion chassis for a second floppy drive.)
- Zip disks - part of the project above.
- Keytronic numeric keypad - actually an IBM LPFK (see http://www.brutman.com/IBM_LPFK/IBM_LPFK.html . I dusted off the old serial port test code and I'm writing a more general purpose library for it.)
- Mouse - Logitech C7 serial mouse for the 386. (Also works on the Jr.)
MikeModified
Nice demo, Mike.
Years ago I had a "Think" sign. It was replaced, somehow, by a one saying "Simplify".
