Hi Alan,
Did you consider grafting a parallel port on to the jrIDE board?
It's a bit tight...but, with today's components, it should be possible?
Of course, the connector is a bit of a problem, space-wise.
....Matt
jrIDE v2 - parallel port
ZiggyTheHamster
Re: jrIDE v2 - parallel port
There's probably enough room for a header connector, but you'd need a header to DB-25 cable.
What I'd rather see is some provision for attaching a daughter board (unpopulated through holes? pads which could be soldered to using a castellated board? both of these are free but require a slight redesign). Sidecar shells and the sidecar connector are both hard to come by, and there are things like this which would be trivial to add to a jrIDE card if there were a daughterboard provision.
Yes. I would totally do that. I think it would be worth it to eliminate that, one, extra, sidecar.
But yeah, slap some header pins in there, too.
