Minor issue with jr-IDE RTC
Postby antongale » Sat Oct 03, 2020 1:22 pm
I've (almost) finished my jr-IDE build (see link below), but I'm running into an issue with RTC.COM. The build I am using is from https://www.retrotronics.org/svn/jride/ ... ebuilt/jr/ but it complains that options /P and /O are exclusive even when I don't state /P or /O in the command line.
However, the real issue lies in the fact that if I do issue a RTC /D /O the time is reported back without issue, but the hard-drive access slows to a crawl and eventually 'disappears'. If I don't use RTC.COM I can go about my day and use the IDE interface etc. without issue. The LED display on my jr-IDE hasn't been populated, I doubt this would contribute to the issue, but I thought I'd mention it just in case.
I took a look at the RTC.C source code and if the variables post_on and post_off are set to 0, why does the statement 'if (post_on && post_off)' not = 0 and ignore the setting all-together?
https://twitter.com/antongale/status/1312411428796665856
antongale
Re: Minor issue with jr-IDE RTC
Postby ctilf84 » Sat May 01, 2021 12:26 pm
I am having the same issue. Getting the same error and drive access becomes unresponsive. Did you ever find a fix for this?
ctilf84
Postby ctilf84 » Sat May 01, 2021 5:56 pm
I found the issue. The RTC version from where you (and I) downloaded it is different for whatever reason. Download it from this link and it worked without the /P or /O options and just the /D option and it works fine and drive access has no issues afterward.
https://www.retrotronics.org/download/j ... pdmdl=1545
That is the link from the jrIDE project page from the main retrotronics site. I know your post has been on here a while so I hope this helps or you had already figured it out.
ctilf84
Users browsing this forum: No registered users and 4 guests
