I ordered a 2GB SD card, so I can't test until it arrives.
I don't want smaller sizes -- I want larger :-) My jrIDE has an 8GB DOM in it, divided into C:, D:, E:, and F:.
raphnet wrote:Speaking bootstraping a PCjr using the cartridge, one thing I would like to offer is a bootable cartridge supplied with a memory card pre-loaded with a version of DOS... But I would need a version of DOS that is 1. OK to distribute and 2. Works on the PCjr..
Trixter wrote:The only issue with DOS 2.0 is that it has limited support for hard drives; FAT12 limits the partition to 32MB. It's not the end of the world; without extended partition support, I believe you can use all four primary partitions to have c:, d:, e:, and f: existing, all 32mb. So 128MB total. But yes, I'd agree with the license that usage like this is allowed. However, it would have to be "extended" to include PC-DOS 2.1 instead of MS-DOS 2.0, since PC DOS 2.1 added support for running programs off of ROM carts -- so single-cart applications like Colorpaint could still run if PC-DOS 2.1 is used.
There's always the "economic recovery" rule: When a product is completely beyond economic recovery for a corporation, they lose all financial interest in it. Distributing free copies of a patched MS-DOS 6.22 on a bootable PCjr cartridge is extremely unlikely to get anyone's attention at Microsoft.
I wouldn't bother with FreeDOS at all. It was created primarily for 386+ systems and is extremely difficult to get running on 808x, and also quite slow.
Fenyx4 wrote:This SD Card not so much.
https://www.amazon.com/gp/product/B00FYX1ABQ
I get a "No suitable partition found.Init failed" error.
I tried reformatting the SD card, tried wiping the partition and recreating it and it didn't work.
raphnet wrote:Fenyx4 wrote:This SD Card not so much.
Could you try running sdpart.com to see what kind of card it is, and what spec version it conforms to? Also please use the 'p' command to print what the partition table looks like.
SDpart version 0.2
Partitioning tool for SD-Cart JR
Running on DOS 5.0
Initializing card... OK
Error reading boot secotr
raphnet wrote:So sadly I can't get to the 'p' command.
This is from a freshly opened one without me having messed around with it.
