raphnet wrote:raphnet wrote:Here is another debug build which will wait 4 times longer. Could you tell me if it makes any difference?
Sorry, here it is: https://www.raphnet.net/electronique/sd ... debug2.zip
That worked! Kinda. Once. sdpart.com worked once when I used it right after booting up. But if I try it a second time (even immediately) it fails again. Rebooted and tried again and it didn't work.
Here is the output from the one success.
- Code: Select all
Card: 74/J' (Transcend) SDC v1.0
Serial 38 00 EC CE , OCR: 80FF800
SD Version 1.0, Byte-addressed
Sectors: 0x003BD800
SD-Cart geometry: CHS=244,255,63
Command (? for help): p
Part. 1 : inactive, type=06 (FAT16B)
CHS: 0,4,4-972,44,44 (0000000FF-00314FCB)
LBA: blocks 000000FF-003BD7FF
Part. 2 : inactive, type=00 (empty)
Part. 3 : inactive, type=00 (empty)
Part. 4 : inactive, type=00 (empty)
raphnet wrote:Nice! Maybe I don't see it, but did you drill a small hole to let the activity LED shine through? Or perhaps you simply trimmed the enclosure "lip" near the LED?
Ooo, I hadn't thought about the LED. I'll experiment tomorrow to try to get it visible.
Here are some pics of what I had to trim in case it helps. It was white PLA spray painted with black before the trims so you can see where I made cuts pretty clearly.
https://photos.app.goo.gl/4Qwu6uJ6N4RQggRe9
https://photos.app.goo.gl/jfA1hdZ6iYRnVmYM8
https://photos.app.goo.gl/KMjb51wSrsg2j8p87
https://photos.app.goo.gl/sKBKWbKHUFgGD8VM7
On the base I had to;
1. trim near the screw holes making them thinner
2. trim part of the thin part of the back (I overcut this part)
On the top I had to;
1. trim part of the back both the thin and some of the thick
2. trim a stand thingy that was bumping into C11 on the board. (I think it would be possible to move it)
raphnet wrote:I should have released a slotted cartridge STL already... I'll try sharing a new STL with a built-in slot in a few days.
That would be great! Wish I could help more. But fear I have no experience with 3d model editing.
