The first lid seems to have typical paint—fairly even, if a bit mottled:
Mike mentioned the effects of heat on the paint. I hadn’t made that connection before, but the pattern is obvious now. In this example, you can see spots that were above the memory card and fan:
Here’s another lid, again with spots, but now with uneven coverage:
This lid has spots, but the paint is very light in general except around the vent holes, the front of the disk drive, and part of the power board. Did this Jr live a hot life, or was the paint always rather light?
And then there’s this lid with distinctive charcoal gray paint. Is this the expensive silver paint used on early Jrs?
