DAMAGED REAR CONNECTORS ON THE PCjr
Due to the makeup of the JJLKLPT and DSC connectors on the rear of the computer. they can be easily damaged. The pins can be bent or broken off. We have found that repair of these connectors is fairly easy. First locate the connector with the broken pin. Unplug the Junior and remove all internal parts including. power supply. 64K memory card, disk drive. controller card. and modem. We remove the mother board from the PCjr shell for easier access to the connectors.
With small side cutters locate the broken pin from the inside and cut it off 1/4" above the mother board. With small needle nose pliers pull the remaining piece of the pin out of the connector. Locate a unused connector like the "L" or "C" port and snip one pin lose at the surface of the board. Pull this new pin out and push it into the connector hole that needs a new pin. Align the new pin with the remaining 1/4" segment of the old and solder them together. This substitution works well generally. however. on some occasions I have swapped the complete pin by unsoldering it from the system board and bending it up slightly to remove it,
griff wrote:I looked up that document you quoted and it is quite interesting. I just might give desoldering the whole connector a go and swap out some of the cassette pins. Thank you for the info.
