Re: Paku Paku -- 1.5 released 21 Mar 2011
Postby deathshadow60 » Sat Apr 09, 2011 7:39 pm
Should be ok, tested fine on the 1k... I'm assuming the problem was on the jr?
Is it possible to get a screencap of the issue? Double check that the copy you have isn't corrupted and you overwrote all the files.
deathshadow60
Postby Trixter » Sun Apr 10, 2011 7:53 pm
I just played on 5160 with CGA, joystick, adlib and it looked fine to me.
Postby Vorticon » Mon Apr 11, 2011 8:58 pm
Yup. It turned out that my files were corrupted again... In any case, it runs just fine now. Really amazing conversion. As a matter of fact, the non-Jr version runs better than the Jr specific one, where in the latter the colors seem a bit oversaturated and the power pellets sometimes become flashing dashes.
One little bug: the high scores are not being saved, which is a pity given that I hit 139000 on my first try :mrgreen:
Postby jmetal88 » Thu May 12, 2011 12:25 am
I noticed something interesting - the game is in black and white when I hook up to a TV via composite out. That's only the standard version, the T1000/Jr version is in color.
Postby deathshadow60 » Wed Nov 09, 2011 1:15 am
Version 1.6 is now out, and I've made room on my programming page to give it an official home.
http://www.deathshadow.com/pakuPaku
fun stuff... so in revamping the code, fine tuning EGA and VGA support, and adding MT-32/General Midi, what did I break on the Jr?
deathshadow60
Re: Paku Paku -- 1.6 released 9 November 2011
Postby Vorticon » Sat Nov 12, 2011 1:38 am
Looks great and plays great. The high score bug seems to be fixed. However, I did notice that the joystick calibration is a little off, but it is quite possible that my joystick is acting up. Fun game.
Postby deathshadow60 » Tue Nov 15, 2011 6:19 am
Vorticon wrote:Looks great and plays great. The high score bug seems to be fixed. However, I did notice that the joystick calibration is a little off, but it is quite possible that my joystick is acting up. Fun game.
Actually, and this is a laugh, it appears I'm not waiting long enough between joystick reads for the interface to 'normalize'... looking into that now. I might have to go back to the old joystick routines because of this -- or investigate other ways of handling it.
deathshadow60
Postby Vorticon » Fri Apr 05, 2013 11:39 am
I replayed that game recently, and yup, the joysticks definitely are not behaving as they should. Are there plans still to fix this little issue? I can play it fine with the keyboard, but it's more arduous...
Postby Trixter » Fri Apr 05, 2013 12:30 pm
I noticed that last week -- the fix is really easy, just wrap the joystick timing loops with CLI/STI. Works like a charm.
He used to have this in 1.5 but took it out for some reason in 1.6. Not sure why, since interrupts will definitely occur when you're trying to read a value from a joystick. So the old code here:
function joyStick1Axis:longint; assembler;
asm
   xor   ax,ax
   xor   bx,bx
   mov   cx,$7FFF
   xor   di,di
   mov   dx,stickPort
   out   dx,al
@loop:
   shr   al,1
   adc   bx,0
   add   di,ax
   in    al,dx
   and   al,$03
   loopnz @loop
   mov   ax,bx
   mov   dx,di
end;
...should be changed to this:
asm
   xor   ax,ax
   xor   bx,bx
   mov   cx,$7FFF
   xor   di,di
   mov   dx,stickPort
   cli
   out   dx,al
@loop:
   shr   al,1
   adc   bx,0
   add   di,ax
   in    al,dx
   and   al,$03
   loopnz @loop
   sti
   mov   ax,bx
   mov   dx,di
end;
Postby Vorticon » Fri Apr 05, 2013 6:05 pm
Would you mind patching the executable and posting it here? Or if you could give me detailed instructions on how to do it, then I can take a stab at it. I assume one would have to use DEBUG on the Jr...
