Anti-Virus Software
Anti-Virus Software
Postby James » Sun Mar 10, 2013 6:19 pm
What strategy are you using for Virus prevention/detection? There seem to be very limited options for DOS virus detection and none that I found will work on anything less than a 386. The programs I have found are VirScan, a German DOS scanner, Dr. Web, a Russian Antivirus software company that makes a DOS version and F-Prot, which is discontinued but had an update as late as 2009. I am Leery of the Russian product, Dr. Web. VirScan, the German product, is nice and I was able to stumble through the German directions. VirScan is available at http://roseswe.ez-web.de/
Scanning the files with a windows scanner may not be effective. Copying the files over to a modern machine and then scanning them in a DOSBox window with a DOS scanning program seems to be the only option available. That does not help with hidden files and boot sector viruses.
Re: Anti-Virus Software
Postby jmetal88 » Sun Mar 10, 2013 8:52 pm
Way back when, I used to use a program on my 286 laptop called ViruCide Plus. I don't know if it would still be useful today, though, if you could even find a copy.
Postby jmetal88 » Sun Mar 10, 2013 9:07 pm
Oh, interesting. I just stumbled across this site on a search, and I didn't remember this, but apparently ViruCide was licensed from McAfee:
http://www.danielsays.com/ss-gallery-do ... e-224.html
I wonder if it was really just VirusScan with a name change, then?
Postby Trixter » Sat Mar 30, 2013 2:01 pm
If you look around you should still be able to find F-Secure for DOS in older archives (simtel?) Also, IBM PC DOS 2000 has a built-in virus scanner and the definitions are likely to be current through 1994.
If you're looking for a modern, updated, virus scanner for DOS, such a beast does not exist. I trust my windows scanner to catch things because nearly everything I do with vintage machines goes through my windows machine (both to and from them).
Postby James » Sat Mar 30, 2013 6:30 pm
Actually there are at least two current DOS virus scanners available. One is from Germany and one is from Russia. I have been using the German one but not on the PCjr as it requires a 386+ processor. What I have been doing, besides scanning new files, is copying the files from the PCjr onto a modern computer via the network and then scanning them in a DOSBox Window. It is in German but the technical terms are close enough that I can figure it out. The URL is above.
F-Prot updated their DOS version until 2009. It also requires a 386+
