SD-Cart JR: An MMC/SD card reader cartridge
Jiidari
Re: SD-Cart JR: An MMC/SD card reader cartridge
Post by Jiidari »
It works!!
Thank you so much for the extra help figuring this out. I had been limping along trying to use a linux boot disk on an old laptop. Once I did a full linux install everything behaved much better.
This is great, thanks again!
(853.07 KiB) Not downloaded yet
adrianchadd
Post by adrianchadd »
hi! this looks cool!
I see there's a problem with it fitting the ROM in a socket in the cartridge slot. (I picked up a pair of ROM boards off of ebay to experiment with, it looks like it'll have the same problem.)
A friend used these in her cart project to make a ROM socket that fit in the socket profile - https://www.peconnectors.com/sockets-si ... d/hws5470/
It requires larger holes so it's not a drop-in replacement for a socket, but it works pretty well!
-a
