This is not a very "fresh" news, but some of you might not be aware that the DOSBox emulator offers PCJr support. Version 0.74 was released on May 12, 2010. Here are some of the changes from 0.73 to 0.74 :
I've been using DOSBox for a while, but completely forgot about the PCjr support in it. I've been using it for my network programming ...
DOSBox is good at emulating games, but it has a few glitches. For one, it doesn't emulate CTRL-Break or CTRL-C handling at the DOS prompt. These are not normally used in games, but it limits the normal applications that you can run. DOSBox also seems to ignore requests to change the DOS time - the time command doesn't accept user input, and the DOS system call seems to be ignored.
I've been using the H-A-L 9000 'megabuild' of DOSBox - that's the version that adds the network support and other goodies that standard DOSBox doesn't have.
CTRL-Scroll Lock does a break, at least in GWBASIC, not sure about Dos. Does anyone know if DOSBox emulates a PCjr modem? (I know, why would I want it to!) I wrote a BBS in the early 80's and all I had was the PCjr modem. I want to play with putting it up again so it can be telnetted into (not that it was anything great).
