If you wanted to give this a shot, I'll have a few devices in DIP packages here next week. Device simulators are great, but I don't really trust things until I get them on a board under a scope. So I can do that next week.
I took a quick stab at translating the schematic logic into WinCUPL HDL. As I was doing it, it occurred to me more than once that this is pretty complex for the simplistic product terms in a 22V10 but it didn't complain when I compiled and it did produce a JEDEC file. So I'll try and program a device next week and test. I know it will fit in an ATF750 but that's twice the cost (but pin compatible).
If there was going to be a one or two off proto build from wire wrap or jumpers, maybe it could be co-routed for both designs.
- Attachments
- pcjr-p1.zip
- Rev.P1 of 22V10 HDL code
- (1.75 KiB) Downloaded 229 times
Yeah, I've investigated the idea of putting an RTC in. It's definitely doable, but it's something we'll need to write out own drivers for (which I might actually be able to do, after figuring out how to interface with the clock in the Booster).Lutiana wrote:Okay, so my understanding is that if we use these chips (they essentially PLCs right?) then we open up a ton of space on the board. Does this mean we can add a RTC now?
I am thinking, an IDE/RAM/RTC card would be a one stop sidecar for most, I know I would be completely set with those 3. We can just make a jumper block to enable/disable any of the 3, so people could configure the sidecar as they need it.
Personally, it's not an issue for me to loose the Booster clock anymore, as I got Maxim to send me a couple free samples of the DS1216E (one of which is now sitting comfortably in one of my system ROM sockets).
Well guys, I just submitted another sample request to Maxim, this time for the DS1511Y+. That might be a good choice for a sidecar based RTC.
Ouch! $24.
I know, the price is terrible. If I can get a free sample, though, I'm gonna try to work with it.alanh wrote:Ouch! $24.
I believe there are somewhat compatible cheaper RTC chips out there, though.
EDIT: Jameco has it for a little under $19.
http://www.jameco.com/webapp/wcs/stores ... 1195111_-1
I put a RTC on my ISA prototype carrier boards to evaluate and spent about $2 total not including a 2032 battery. But it was SMD. Maxim/Dallas is proud of their stuff.
Ha, yeah. Well, the chips that are multiplexed for data and address are a lot cheaper, as are the chips that aren't multiplexed but only have a 4-bit data bus. At any rate, it doesn't hurt me to get some free samples.
Here's one of the 4-bit chips I was talking about:
http://www.jameco.com/webapp/wcs/stores ... SF&CID=GMC
Alright, Alan, here's a schematic with your 22V10 in it - I'm hoping I got it hooked up in the way you intended. The symbol I found included the wrong configuration of pinout for the way you have it set up, but I haven't changed it yet.
- Attachments
- JR-IDE-V2.pdf
- (173.03 KiB) Downloaded 220 times
What do you mean wrong pin out? Pin 12 is GND, 24 is +5V, 1-11 & 13 are inputs only and the rest inputs or outputs. Signal assignments are made by pin number in the code. BTW when you start routing, you can move any Pin-I/O assignment around within those constraints and then change it in the PLD file. Can often save a via or two or three...
I didn't get a chance to order samples yesterday, but I will today. I just want to wire up the circuit as it exists on XT-IDE mkII vs a PAL and truth test both with a MCU and check propagation times etc under a scope first. Should be done with that by next weekend.
