I'll test out the latest version later tonight.
"Fill your jrIDE" project now ready for testing
Re: "Fill your jrIDE" project now ready for testing
Relax, I only place executables in root for quick testing
Ok I tried the latest version of TDL and I'm still getting the reboot issue every time. I've attached my log file and the backpack.sys file I use just in case that is the problem.
- Attachments
- tempest.zip
- (14.9 KiB) Downloaded 228 times
When it reboots, do you see the PKUNZIP screen at all?
I just want to confirm, you are loading jrconfig, right? If you don't, the program stomps on itself when it writes to video memory (which I verified, but is not at all surprising).
If you are running jrconfig, perform this test:
If that reboots, then the problem is pkunzip. If it works, then edit TDL.INI and change the "swapping" line to read "swapping=disabled", delete everything in c:\temp\cache.dir, and try running TDL.EXE again and let me know what happens.
Is C: your backpack drive?
c:
mkdir c:\temp\cache.dir\billiard
cd \menu\files
C:\MENU\utils\pkunzip.exe -+ -- -d BILLIARD.ZIP C:\TEMP\CACHE.DIR\BILLIARD\Is C: your backpack drive?
I saw the text for pkunzip briefly before the reboot, but I don't think it actually got to unzipping anything (just displayed the copyright message). I'll try those steps tomorrow and let you know.
My backpack drive is D but I have it assigned to B. C is my hard drive (well DOM module anyway).
I entered the commands manually and got the same reset I was getting from TDL. What does this mean?
It means that pkunzip is rebooting your computer, which I have never seen before in my entire life. Maybe you should run through the diagnostics (ctrl-alt-ins) for memory, maybe see if pkunzip 2.50 also reboots your computer, maybe try unloading the backpack driver. The version of jrconfig I'm using is 2.14, the non-ramdisk version, maybe try that with exactly this config.sys line:
stacks=0,0
device=jrconfig.nrd -t3 -v64
What's the difference between the two jrconfigs other than the RAM disk (which I don't use)?
EDIT: The new pkzip didn't make a difference
EDIT2: Looks like the older jrconfig doesn't work either.
EDIT3: Ok without the backpack.sys file it works. So it looks like that's the problem. I found one on minuszerodegrees.net which was a little older than mine and seems to have fixed the problem.
Thanks for the update, and glad it wasn't my software. That was bizarre.
Happy to report that TDL for 386+ computers works like a charm! Incredibly useful piece of software...
Cool, thanks for checking it out. Feel free to PM or email me feature requests. I plan on launching it (pun intended) this summer as free time permits.
