Zeliard - No Joystick
Post by Chuckphd53 »
I recently installed Zeliard for my grandson to play, and showed him how to use Keyboard /Joystick with Ctrl-K /Ctrl-J.
after I rebooted, after dinner the joystick would not work at all.
Tried :
rebooting,
different joystick,
re-ran install, with Joystick Yes and No neither worked ( this is saved to the resource.cfg file)
Running Dos5.00 game is on Drive C: JR-IDE
this was installed from drive A:
TandyMode video
I am perplexed that I did have it working , but only once.... strange...
Considering using DOS3.3 and trying, but he is playing right now so I have time to write this....
Chuck
Re: Zeliard - No Joystick
Hit CTRL-ALT-INSERT with the joystick(s) plugged in and go to the joystick testing section, and make sure they work and are calibrated, then try again.
Joysticks are functional, Donkey Kong and other games work ok...
Just Zeliard, and the kicker as I mentioned it did work one time....
I think it is gonna take some configuration tweaks, ....
