I then started the PCjr, watched the jrIDE BIOS load with POST numbers on the alphanumeric display, and booted to DOS 3.21.
Next, I used the date and time commands to set DOS to the current date and time. When I ran rtc /r I got what appeared to be normal execution:
Next, I manually changed the DOS date/time, and then used rtc /d with the intention of setting DOS date/time from the real-time clock. This time I got the following:JR-IDE - Setting RTC Clock from DOS
Thursday October 25, 2018 - 6:14:40p
The first couple of times I tried this, I left the jrIDE's dip switches in the default positions as received -- switches 1, 2 and 3 all off, meaning that the RTC would use IRQ7.JR-IDE - Setting DOS Clock from RTC
ERROR: Unable to update DOS time
Unknown Unknown 24, 1958 - 6:42:42p
Noting that the Nerdly Pleasures writeup on the jrIDE recommended using IRQ2, I then changed those dip switches to off, on, off. This made no change, and I got the same error.
Any suggestions on how to fix this? Is there any other initial setup or config I need to do? Any possible issue with the DOS version?
