DOS 5.0 with the jrIDE.
Re: DOS 5.0 with the jrIDE.
Post by Chuckphd53 »
Ok I'll hunt around some more...
ZiggyTheHamster
Post by ZiggyTheHamster »
FYI: If you patch the boot sector in VirtualBox, the boot sector will no longer boot in VirtualBox.
Also, I found that I couldn't FDISK or FORMAT from DOS 5 in VirtualBox and have the disk be read on the jr. I had to run FDISK and FORMAT on the jr. Then the VirtualBox DOS 5 (running from a boot disk, because again you can't boot off of it anymore once patched) could read the disk as well as the jr.
ZiggyTheHamster wrote:FYI: If you patch the boot sector in VirtualBox, the boot sector will no longer boot in VirtualBox.
That's kind of expected ... it's a PCjr specific patch.
Make sure that your patched diskettes are clearly marked. They won't boot on real machines either, except for the PCjr.
