Software for Cluster adapter
Is there software required to connect 2 PCjr's with Cluster adapters?
Re: Software for Cluster adapter
Yes ...
One side is the server, which runs on an XT or AT class machine. On the PCjr side I think the cluster adapter has enough of a BIOS extension to do a remote boot from the server. There is also software for passing messages. I'm not sure what the file sharing solution looks like; it has been ages since I tried it.
I've not posted the software because of copyright issues.
So you cant connect 2 jrs directly to each other? You need a PC?Brutman wrote:Yes ...
Technically speaking, it is an Ethernet-like network, so you don't connect any machines to each other - you connect them to the same segment of wire. The problem is that the software assumes a client/server setup, where PCjrs are clients and there is a server on the network. It's possible to send data from one machine to any other machine, but you need to write your own software to do that.
When I have a lot of free time I want to make a version of mTCP that runs on cluster. That would give you TCP/IP between the machines. I'll have to do something to make a gateway between the cluster network and Ethernet to make it usable though.
Brutman wrote:Technically speaking, it is an Ethernet-like network, so you don't connect any machines to each other - you connect them to the same segment of wire. The problem is that the software assumes a client/server setup, where PCjrs are clients and there is a server on the network. It's possible to send data from one machine to any other machine, but you need to write your own software to do that.
Sounds like null modem cables would be the best way to directly connect 2 junior's, then, if it's too difficult to do with cluster adapters.
